OOPS!!!
Hey Rich....I was joking. :-[ :-[ :-[
No you can't fit the funnel like that the inner mounting plate will totaly block the gas flow.
Hot gasses will move upwards under natural convection flow and will be driven faster in that direction by the cold air entering from the lower side damper holes and the draw/draught created by the funnel.
By having the inner mounting plate go all the way to the top you will create a barrier between the gasses and the funnel.
This will trap the gasses in the top of the casing and they will try and flow down the barrier, and the inside skin of the casing, creating a swirl vortex with burnt gasses mixing with fresh cold air, which will give all sorts of problems.
You must have a GOOD, CLEAR, LARGE and FREE path in the upper casing to the base of the funnel.
A couple of ideas....
1/ move the funnel to the right of the mounting plate or..
2/ shorten the mounting plate by cutting the top away, just leaving the bottom stud holes to support the boiler.
I am assuming the bottom of this plate rests on the damper slide guides to provide support.
I would also cut a large opening in the plate, below the lower stud holes, just leaving a vertical strip at each side to maintain support.
This will ensure maximum free passage for gas flow.
Your funnel should be OK at 1" dia but make it around 10" - 12" high, this will aid in getting a good draw/draught going.
Sorry to dampen your spirits but it has to be I am afraid...... FISIKS IS FISIKS, as they say.
Keep happy.
Best regards.
Sandy
