It was probably my fault. I put the .25 bore in the gear first, then was turning the tit down to 3/8" diameter as per the drawing. I find that cast iron eats up HSS tooling very rapidly, so I was using a carbide. If you let carbide get a bit dull, it puts a lot of pressure on what you are cutting. It was more a matter of my questionable machining talent than a fault of the cast iron. I realized after my last post that this gear is turning on a stationary steel shaft, so I couldn't really make it from steel or it would gall. I dipped into the Rupnow fortune and bought 3" of 1.5" diameter brass for $15.--That will make a good gear and will turn without galling on the mild steel shaft.
