raveney
Screen Cooler Tank
I didn't seem to come across an empty can that matched the dimensions I wanted, so I salvaged a heavily tarnished foot of 2" copper pipe and a coil of 1/8" icemaker line to see what could be done.
Slit the copper pipe lengthwise with a hacksaw in the vise, and then heated it cherry red with the turbo torch and firebrick hearth. Carefully pried it open and then flattened it using the vise jaws while turning over end for end. I have aluminum soft jaws in this vise. Then I was able to form the semisoft copper over a stub of 3" pipe to form a 3" tall by 3-1/2" OD cylinder for the tank. I then silver brazed this and cleaned it up in the lathe on some wooden formers.
The leftover copper had enough for the floor of the tank so that was silver brazed in next, and then again, and one more time until it held water.
I am using Kapp Zapp 3.5% silver solder in a half pound roll as it is much cheaper per foot compared to the Harris brand. It does work okay with the white flux, but does not seem to work at all on ferrous metals.
I had planned to make three hoops out of the 1/4 OD copper tube, but only ended up using the one as a clamp for the screen. It was too large for the scale, and I ordered 1mm x 4mm half round online to replicate the "bulges" that are found on galvanized tubs and barrels. I was able to mill the tubing into half round pieces after clamping it in an aluminum jig that has a 1/4 ball end mill groove to hold the tubing flat.
Not really sure how the top sprayer part is made, so I sketched a few ideas and ended up with a 1/4" by 3/4" ring with 12 1/16 spray holes. The "hood" is a loose fit over this ring and will hopefully allow the cooling water to cascade down the screen/funnel shape. The screen material is 20 mesh copper.
I wrestled with the screen material enough until I chose to make a wooden former on the lathe. This has a base the same size as the tank (3-1/2") and tapers at 26 degrees. Pinned the screen on the wood and will attempt soldering it another day.
