raveney
Crankshaft
This went well after re-reading very helpful advice from sprocket and others on this forum. The drawings also showed the outer dimensions of the drill rod reduced to allow better silver braze penetration and perhaps offset growth after heating.
Dressed the 7/16" and 3/8" drill rod using emery cloth in the lathe to a good sliding fit in the ball bearings ~0.4370" and ~0.3745" for the rod journals. Made the crank throws out of 2" x 3/4" rectangular hot rolled slices and gang drilled and machined as pairs. I didn't round over the throws yet. The alignment half circle pieces were a really good idea and super easy to make on the lathe and hacksaw in half. The wire is easily cut and spacers removed while the brazing continued. The black areas are the spacers and not the drill rod.
The assembly remained flat (in plane) but is very blackened. I used the white flux this time because of the tight fits sliding drill rod inside of holes would be very hard with the black grittier type. I let it cool completely and then placed it in a citric acid bath while I worked on another part.
It didn't really flow well where the white arrows are, but that part is being removed anyway. I will need to be careful removing the excess fillets at the throws
I think it's a good part, but will measure it after cleaning and removing the excess materials tomorrow.
Made a pair of brass camshaft bearings and pressed them into the brackets instead of soldering. This kept my impatience at bay while the part soaked in the pickle bath.
