This engine is to run on propane. I built the demand valve. I had gotten a propane hose with an adjustable regulator.
Rustkollector had said you need to open the needle valve quite a lot more than for liquid fuel. Also, the carburetor that was recommended
isn't made anymore, so I made one to GBritnells plans. When I first tried to start it, I would get some pops, but only with my thumb choking the air intake almost fully. Seemed like it was way too lean even with the needle valve way open.
Sometime in here, I found I had a weak joint in one of the connecting rods. It separated from the big end. Grrr!
So, a bunch of disassembly, clean up the parts and re braze. This time I drilled a tiny hole in the side of the big end to meet the hole the shaft of the connecting rod as a vent, because I wondered if pressure buildup had kept the silver from penetrating. There was plenty of heat.
In reassembly, I changed a few things about the cams. The cam carriers have 4-40 set screws and I milled a flat for those to sit in.
The cams themselves had 2-56 x 1/16" set screws which use a .035" Allen key. They didn't feel like I could get them tight enough to prevent slipping, so I replaced them with 3-48 x 3/32" set screws which use a .050" key. Not much bigger, but they feel a lot stronger.
To solve the lean mixture, I made a restrictor for the air intake:
And made a new jet with a larger hole, larger needle, and larger feed line:
I was trying not to do anything I couldn't undo if it didn't work.
I had gotten short runs with no coolant in case I had to take it apart again, so yesterday I filled it with coolant and got it running!
It runs. I think it will need a larger cooling system as it heated up fairly quickly. Right now, I'm just happy to have it running.
I guess the next thing is to make a more permanent wooden base for it and eventually figure out a generator.
That's all for now.
Thanks for looking!
Doug
