- Dec 31, 2010
- 822
- 220
That's a sound procedure. One I've used many times to check final cam timing. Assuming your rockers are not a 1:1 ratio if you move your dial indicator over to the top of the valve rather than the top of the push rod and remove all the lash you can also measure your valve lift while you're at it.
BTW. If you intend to have a bit of valve lash, you should measure at the valve to get the actual valve timing since the lash will effectively alter the timing. (as I mentioned before) lash will effectively cause the valve to open late and close early.
Looks good to me.
Looks good to me.
