1" Bore x 1" Stroke Vertical i.c. Engine
This is a video I made today, 11-june-2021 of my vertical i.c. engine 2021. I have been trying to make a set of cast iron rings for the piston, and as part of that I built a new cylinder and new piston to accept cast iron rings, but ultimately I was not successful. Finally I decided that I should put this engine back together, so I enlarged the top ring groove to .093" wide x 0.058" deep and put a Viton ring on it. This engine can now go up on the shelf with all of my other engines. I am still after cast iron rings that actually work, but will be trying them out on a different engine that is a lot simpler to take apart and access the piston.----Brian
