olympic
I wondered about that. I may have to look into modifying my "real" band saw with a countershaft.
Thanks.
Thanks.
I have a hacksaw... and a sore shoulder.
Great idea, Brian. I have an old Pinto 4-speed out in the shed, and that may just work.Olympic--if you already have a wood cutting bandsaw and want to use it for wood and/or metal, instead of putting in a jackshaft, take a look at a 3 speed standard automotive transmission. That way you can select one speed for cutting wood, and one for cutting metal, and a third gear for anything in between. you wouldn't use the reverse gear for anything.
Oh, well the wacky weed is legal here for a few years now.I don't have the best set-up for wintertime painting here. It goes something like this--Get all the parts to be painted ready for paint and held in spare vices, vise grips, or anything else that's handy. Set up my big garbage pail with a board on top outside my office door. Set all the fixtured parts outside on the board, then paint them outside. After 10 minutes, move all the fixtured pieces inside where it's warm to dry. Wait one hour---change all the fixtured pieces around so the unpainted side is exposed, then carry them all back outside to set on the garbage pail. Spray paint again outside, then carry them all back inside to dry. It keeps most of the paint stink outside. I may get a bit high setting in my office until the paint is totally dry, but ya gets your kicks wherever you can----
Google earth!! Your address is on all of your drawings you publish!Olympic--where the heck are you, and how did you know about all my power-lines?
I’ve seen your power lines too!!
By the way, next time the truck or the satellite flies by, can you make sure your lawn is cut and those bushes trimmed up???
This morning yielded a pair of bolt on counterweights for the crankshaft...
No Google Earth needed here; I used to live in Barrie, and know Carson Rd. well.Olympic--where the heck are you, and how did you know about all my power-lines?
