Pete,
Are the cams made the usual Westbury way, that is a little holding jig with a timing plate on the end and you cut each facet on the lathe?
If so, just be careful, it is very easy to make your cam backwards. DAMHIK. But once you get it right, following his instructions, it makes a very nice cam indeed. To blend in the flats, I just used a bit of very fine emery strip stuck onto a lolly pop stick, and turned it in the lathe. It only takes a few seconds on each lobe.
I threw away the jigs I made on my last big clearout about 3 years ago, but they are worth keeping as they could be sent around the world to help others out who are building the same engine, as they weigh very little.
Best of luck
