DickInOhio
- Mar 8, 2011
- 91
- 115
That's nice. Can you elaborate on your pinning method. Are they tapered & pressed in with Locktite for example? Did you also have some sort of assembly jig for all the components so they held in position for drilling? The counterweights look black, or is that the lighting?
No jig was used. The crankshaft is put together in thee pairs. Each pair is made-up of two individual webs and a middle double web with the correct 120deg offset. Each pair is assembled, loctite 609, and pinned with a harden straight 1/8 dowel. Each of the three pairs are then put together with the proper throw using a digital angle gauge and pins. That's probably clear as mud. Hard to explain.
The material used for the webs is 1144 stressproof steel which has a dark gray outside color.
