Just came across this thread. That's some nice work. I have a feeling it'll be a bit of a struggle to tame that engine down to a nice idle! Have you decided on a compression ratio?
Chuck
Do you have a favorite compression calculator. I found several online, but they cause me to do a lot of head scratching.
I tried to attach one but the file size is too large. Sorry
Thanks Steve. Is it one I can find online ?
This one might work for you http://www.cbperformance.com/v/enginecalc.html
I don't really have a calculator. If you know what compression ratio you want, you can subtract 1 from it and divide the result into the stroke to get the head clearance you'll need. For example, if you want a compression ratio of 5:1, divide 4 (5 - 1) into 1.25" (your stroke) which gives you a head clearance of .3125". This will get you pretty close but doesn't consider any openings outside the cylinder walls or in the head.
Chuck
Dick...Will this engine have an open crankcase, i.e. all components visible?
Frank
Finished assembling the crankshaft today. It turned out really well, straightest one yet
Next will be the rods i think.
