- Incidentally: I can strongly recommend a cheap way to "get the Regulation info" - Buy a back copy of "Live Steam and Outdoor Railroading": Volume 40 No. 6. The article by Kozo Hiraoka is really the best text book I have seen on the subject: He is a genius teacher. - I use this in place of all the other books I have, as it has such clear and uncompromising details on what MUST be achieved as a minimum to be approved to ASME Regulations.
But I must add, that this does not cover any tubes experiencing COMPRESSION forces from the water/steam - such a flue tubes. In the case of COMPRESSIVE forces on COPPER tubes, you need to de-rate the Maximum Permissible Stress to 21% of the Max. Permissible Tensile Stress - according to the worst case I have read from internet sources....
And considering that many boilers:
- with a single fire-tube (for a blow-lamp) have cross tubes,
- Outer-shells have penetrations for Steam domes,
- Inner firebox tubes on vertical boilers have penetrations for coaling,
there is another ASME regulation applying to pressure vessels - including boilers - that states the STRESS CONCENTRATION FACTOR shall be taken as 3.3 - Whatever else an individual may think, calculate or ignore.... - This has the major effect of reducing the NWP to 30% of that otherwise calculated (I.E. If you have missed/ignored the SCF).
Basically this has caused me to de-rate some of my boilers, because I had originally used other stress concentration factors (typically 2.2 ~2.7 depending on tube size, shape and hole size) because I designed boilers based on my general engineering knowledge, and some text book tables, in ignorance of the ASME requirement.
In summary, unless you feel you can fight a court case for "exemption", you have to do a hell of a lot of research to find the Regulation quirks that affect you designs... And I don't know where I can go to ask for confirmation or correction of what I am doing! Most "inspectors" can inspect to their rules, but can't confirm your calculations, because it isn't their job to know or be able to do so.
And as far as I can determine, outside of the USA, one has to "Do one's best" as the Regs are so hard to find and interpret...
Sorry to be so long-winded about this, but I have pondered and researched for many hours to try and get to this semi-sensible stage...
