G'day, Steamchick. Many, many thanks for your input, especially the discussion of compressively stressed copper tube. I do have Kozo Hiraoka's book 'The Pennsy Switcher' and he uses larger flues in its coal-fired boiler. He reckons that fewer large flues are to be preferred. That suits me and my gas intentions, except that he calls up flues of .787" OD x .047" wall thickness, which he says should be doubled if in 7-1/4" gauge, (.094"). Both of these seem a bit light to me at 80 psi., and in fact, I'm considering using .125"x1.75"x450 long tubes for my flues, but I have my doubts about the compressive stress at those sizes, especially as we are, I understand, talking about annealed copper tube. Another project I have on the back-burner, is rebuilding a 6" dia. stationary boiler I built years ago, which has a 4-1/2" (approx) inner firebox. All from 3mm copper tube and the inner firebox has bulged inwards: the project is rebuilding and installing radial stays at the firebox. The design was from Model Boilers and Boilermaking, by K N Harris, design no 9, page 163. As you say, better to use somebody else's design.....hmmmm.....
My Sweet Pea-type boiler, with round firebox, will certainly be stayed. That's one of the 'improvements'!
I've been fiddling for what seems to be ages with gas burners/burner configurations and as you say, enough primary air is THE issue and nozzles are 'interesting', shall we say. I'm pretty competent with 0.4mm holes! I have a 'range' of jets in 0.4, 0,.5, 0.6, 0.8mm etc sizes and all sorts of weird and wonderful gadgetry, to supposedly control air. I have quite a few venturis, but my reading on these seems to show that a pipe reducer might do the same job! My venturis are 'sophisticated' by comparison, fabricated from 2mm copper, finally shaped with a very nice(!) steel taper mandrel (2" dia) and a fly press and die. They look a bit like the bell of a small trumpet.
It seems, too, that my 'in flue' burners might be better served with what I've seen called a 'glow cones' and I've tried these, but they're a bugger to make and support in the flue and they are relatively short-lived. I have a burner 'stick', which has burner 'mounts' along it, intended to have about eight gas nozzles evenly spaced along the flue, but I haven't yet tried it out in a flue. I suspect it'll probably self-extinguish and just how to support it in the flue is interesting, too.
Ragards
Wazrus
