Brass_Machine
- Aug 28, 2007
- 1,314
- 7
Brass_Machine said:Base - Will be made thicker and larger footprint to allow for use of cap head screws and some detail work.
Bearings - a threaded 6-32 hole to allow the use of oil cups
Cylinder - longer shaft to allow mounting of the flywheel on the outside. (extra length TBD)
Extra spacer - Machined to the width of the flywheel to allow flywheel to be moved to the outside of small bearing.
Cam Ring - Machined to allow lettering at the top. Color still undecided
Forks - Wes's idea of a set screw
So these are the modifications to date. I have left out the oillite bearing on the small end. Look them over. I want to firm these up and get started on our build.
Eric
