I think what we need is a list of modifications that we are all aware of. So far the base is thicker, we are using oil cups, possibly an angled hole to fasten the flywheel,and set screws on the forks I think .
I was playing with the cam ring to see what else might work easily. I have drawn a lot of this engine but with no regard to changes (what I've mentioned is cosmetic) because as time allows I want to build another one complete.
I had also planned on using a small oilite bushing on the small bearing end I'm making and allowing it to be slightly above the surface on on side to act as a thrust bearing , keeping the valve body in arrangement.
Dick
