Lawjit--There seems to be a few things you don't know about hit and miss engines. There is no cam or lifter for the intake valve. It is held in the closed position by a very light spring. When the piston moves from top dead center to bottom dead center, it creates a vacuum in the combustion chamber, and this vacuum "sucks" the intake valve open and "sucks" the air/fuel mixture into the cylinder. The intake is what is called an "atmospheric intake valve", because it is actually atmospheric pressure which opens it. When the engine reaches a high enough speed for the governor weights to fly into the "out" position from centrifugal force, the governor mechanism moves a lever into a position that prevents the exhaust valve from closing. Now--the exhaust valve can't close, but the engine is still revolving at a fast rate--but it can not suck the intake valve open, because with the exhaust valve held open no vacuum can be created. This is the "miss" part of a hit and miss engine, when it is coasting. There is still a spark every time the piston comes up to the top, but with no fuel to light, the spark does nothing. After a few revolutions, the engine begins to slow down. When it slows down "enough", the spring on the governor moves the governor into the "in" position, and this moves the lever, allowing the exhaust valve to close. Once the exhaust valve closes, and the engine coasts through one more cycle, it "sucks" in a fresh charge of air/fuel mixture, and the engine fires or "hits" again, starting the process all over again. This is one of the reasons that it is important to put an "anti flow-back" valve in the gas line feeding the carburetor. With the type of carburetor a hit and miss engine uses, the fuel tank/fuel level must always be lower than the carburetor to prevent flooding. Without an "anti flow-back" valve on the gas line, during the miss cycles the fuel can run out of the gas line back into the fuel tank. When this happens, and the engine wants to suck in a fresh charge of air/fuel mixture, if the fuel has all ran out of the gas line back into the tank, the engine may just slow down and come to a complete stop before it can get the fuel back up, through the gas line and carburetor into the combustion chamber.---Brian
