I decided that I better get busy and make the base to mount the engine on, but first off I thought that I would make a box to hide the electrics.
Before I start, let me fill you in on this, the Woolworth conglomeration is busy building Masters hardware stores around the country, about a year ago they opened one near me, by all accounts they are struggling to make any money, but one good thing is that they stock dressed timber in 6mm and 8mm (and others) thicknesses, with varying widths in Oak, Poplar and I think, Cedar. All very nice sizes and material for the home hobbyist.
I purchased some 6mm x 44mm and some 6mm x 90mm oak. The 44mm is for the sides and the 90 is for the top and bottom. First decision was how to join the sides together, I decided that I would try making finger joins, at least that is what I think they are called.
The first picture shows the 4 sides already machined.
Now I step backwards a bit and I will show you how I machined them in the next picture. I sandwiched the sides between a couple of bits of scrap chipboard and used a 6mm end mill to mill the slots. The bits of scrap are to prevent any chipping of the oak.
Next I applied some PVA glue to the joins and tapped everything together, I also glued on a top and bottom piece, and clamped it up overnight.
After trimming the top and bottom, this left me with an enclosed box.
Next thing to do was cut all the way around to form a lid. I set up a slitting saw in the mill, with a parallel clamped to the table as a backstop. By holding the box down on the table and against the parallel, I fed the box against the saw by hand, cutting through all 4 sides.
On the inside of the lid, I glued some thin strips at each end to act as locators to align with the box. (Sorry, no picture) After a bit of work with some sandpaper, and several applications of some cabinetmakers wax, I now have a box to house the electrics. I will machine some slots in the box later to allow the wires to come out. I did not want to mess around with hinges and catches, that's why I used locators in the lid. I have ordered some rare earth magnets that I will embed in the sides to keep the lid on.
Paul.
