Swifty
Latest update, we have spark!!! but only after I turned the Hall Sensor around 180 degrees, no spark initially, but then I remembered that the sensor only works on one side. I cobbled together a fuel tank and cranked the engine over with my battery drill, it fires and blows out smoke but won't run by itself yet.
But I have a problem with the square bar that works the exhaust valve, Brian stated steel on the drawing but as I had some 1/4" square brass, I used that. However the bar has bent where the holes are for the governor latch extension.I will straighten it out, make the latch extension, and bolt it on. This should provide enough strength to stop it bending again. While I'm working on it, I will put a pin through the shaft to make it easier to turn over with the drill.
Paul.
![](https://proxy.imagearchive.com/af7/af7d56f7123fdf85854e32ad687acd73.jpg)
![](https://proxy.imagearchive.com/20a/20ab8b39998e7dcd931b15472e02cb6e.jpg)
Paul.
