Swifty
I have been working on the valves today, following the build instructions, I turned the stems over length, finished the valve dia. and turned the valve seat in one setup.
Next I turned the valve caps that will contain the spring, I made sure that they were both the same by using one valve in the head and checking the size of the caps.
Next thing to do was to turn up a bush with a 12mm OD and a 3mm reamed hole in the centre, I then used my new 0.5mm slitting saw to cut through one side of the bush so I can clamp the valves to finish them. I turned the head of the valve down to thickness first on both, then trimmed the valve stems to finished length, carefully checking the finished size to only allow 0.05mm gap under the cams. I had previously marked each valve as inlet and exhaust. Last job was to turn the "E" ring groove, 0.5mm wide. I'm going to have to befriend a micro surgeon to help me get the "E" rings on when the valves are in position.
Here are the finished valves and caps.
Paul.
![](https://proxy.imagearchive.com/252/25241ac18e440d7e221321d63d0ec140.jpg)
![](https://proxy.imagearchive.com/43d/43da819b53c7feb72c66e7da329d7d51.jpg)
![](https://proxy.imagearchive.com/b17/b17f960839de2477141485372a4c5c35.jpg)
Paul.
