Swifty--Having just traveled this cam road yesterday or the day before I will tell you what worked for me. Center the chuck on the rotary table directly below the center of the quill in the Y axis. With a 3/8" or 10mm endmill in the quill. Set the rotary table to 300 (or whatever Malcolm suggests for the Lynx---it was 300 for the Jaguar). Bring the cutter down and touch off the part to be milled and set the quill vernier to zero. Lock the Y axis--all the milling will be done with the table moving in the X axis. You will have a known dimension from the size of stock you are using to the major diameter of the cam. (I measure that major diameter as 0.472" (12 mm) on the Lynx cam.) Move the table in the X axis until the part is no longer directly below the quill. Advance the quill whatever distance is required to get down to the major diameter and take a cut, then back the part out from under the quill, again moving only in the X axis. This will leave a flat spot on the top of the cam. Then you start with the table, advancing the quill however many mm is called for and turning the rotary table however many degrees are asked for and each time taking a pass under the cutter in the X axis. When you have went completely through the tables, leave the part in the chuck, and don't advance the quill any more. Just rotate the chuck in 1 degree increments and take a cut each time without moving the quill. Eventually you will have worked your way all the way through until your last cut comes tangent with the flank on the other side of the cam. This is majorly tedious business. I never had a true appreciation for how many degrees there were in a circle till I cut a cam using this method.---Brian
