Swifty
Gus, I have some 0.40mm drills somewhere, left overs from when I was working. Would not even try to use them now.
Paul.
Paul.
Paul.
SOS SOS SOS
Hi Paul,
The electronic ignition must be earthed. ............t.
Don't panic; the reason you need the system earthed is you'll fry the CDI if you try to make sparks without a plug connected. The screen on the plug lead will be adequate to make the circuit, however, as belt and braces either clamp the outer screen to the engine with a metal P clip or solder a flying lead to the screen, put a tag on the other end and clamp it under one of the mounting screws.
How is the compression looking? from Brian's experience with O rings vs CI rings and me spending a week or so getting mine to run, compression is the key.
Will soldier earth wire to cable screen.
Pete
Gus, I hope that you get over that touch of flu quickly, I'm getting anxious to see your Lynx running.
Paul.
