Valves used to be my big Bugaboo with i.c. engines. After constructing a couple of the Geo Britnell valve seating tools, and following my strict regimen of 3 lapping sequences between the valves and seats, beginning with 350 grit, then with 400 grit, then 600 grit, before the engine is ever assembled seems to have sorted that problem out very well. I have built enough different kinds of carburetors now that even though the parts are minuscule, they don't frighten me. I gave piston rings my best shot with the engine I just finished, based on the Nemett Jaguar drawings. I did get it to run---you seen the video. But--at the end of the day, the engine still had rotten compression, and wouldn't idle worth a damn. I pulled the rings out, reinstalled the piston configured for Viton rings, and immediately restored a LOT of compression and great low speed idling. Close examination of the rings showed areas of very little wear pattern--which indicated low or no sealing in that area. This was after 4 hours of "running in to seat the rings" powered by an electric motor. I will not make rings the way that is advocated by Malcolm Stride again. There are other ring making instructions available which advocate making the ring blank oversize on the outer diameter, then spreading and heat treating, then compressing the rings, clamping them in a compressed state on an arbor, and then turning a finishing pass on the o.d. of the rings to guarantee concentricity. If I ever decide to try making rings again, I may use that method.---And yes Swifty--I normally run all of my engines on Coleman camp fuel, which is basically Naptha gas. I was told by Gail in New Mexico that automotive pump gas releases more energy when it burns than Naptha, so I went and bought some high test automotive gasoline to try and get my engine to run with the cast iron rings. It did make a difference, and I was able to get the engine running with cast iron rings. However, at the end of the day, my garage stunk. I stunk. Even after a shower and change of clothes, I smelled like a friggin gas pump. The Coleman fuel is marvelous, in that it seems to leave no smell at all in the garage nor on me.-----Brian
P.S.--Gail in New Mexico must be right about more energy in automotive gas than in Naptha. The engine with cast iron rings would not start on Naptha, but did start and run on the automotive gas. The only explanation I have for that is that the greater amount of energy released by the pump gas gave enough extra "oomph" to the engine to let it make two complete cycles and still have enough impetus to fire again, even though the compression was less than optimum.
