Swifty
Next item to machine is the con rod. I started off with some plate aluminium and bored / reamed the big and small end positions, and drilled where I needed a radius in the corner, the position for these was drawn up on my CAD and the sizes taken.
Next step was to set up the rotary table and indicate the centre, I then clamped down my milling plate. To make it easy to set the holes up, I turned locating pins that I held in the quill in the zero position, located the hole and clamped the con rod down. I then proceeded to mill the outside radius.
Here we have both ends done ready to be finished milled to thickness.
And here is the con rod, just need to drill an oil hole in the small end and clean up with some filing and emery.
Paul.
![](https://proxy.imagearchive.com/0fe/0fe3dbd09f29f995576c67fb458db12d.jpg)
![](https://proxy.imagearchive.com/148/148be386ee997e1fbc14b580ac9156a7.jpg)
![](https://proxy.imagearchive.com/23f/23f40b0a48663851e939ab28e01aa466.jpg)
![](https://proxy.imagearchive.com/9a5/9a5214feb040a68718f261a68f3626e3.jpg)
![](https://proxy.imagearchive.com/c04/c041d1dfc7299bfde7471354123e0758.jpg)
Paul.
