Well it's been some time since my last up date sorry about that but the weather here has bee less than desirable for shop work. The humidity and temp have been well above normal.
Here is what I've got so far I did have a little time out there today before it was just to warm.
Started by getting 2 pieces parted off for the top rings.
Chucked them up in a 3jaw and drilled a .5 center hole and bored the ID deep enough so that when I flipped and did the counter bore from the back side they would intersect. Bored the counter bore on the first side then I flipped in the 3 jaw and counter bored the back side.
Then I quick made a little holding jig to drill the hot end mount holes. Clamped up part and moved to the first location and drilled through the part and the jig. Then I moved to the second location and after that just looseness the part and rotate using drill to line up the hole just drilled with the hole in jig. That way didn't need to move the machine table after the second hole plus I'll hole the line up hole in the jig in the next 2 operations also.
Holes for hot end done.
Set the jig up at the 11 degrees put a .5 tooling ball in the center hole to dial in on. I calculated the distance from that center to where the hole for the stand rods needed to be the center of the ball is .500 above the jig at 11 degrees the part is .400 so the center was .1 above the part.
Then set up the jig a 101 degrees to drill the 4-40 holes for set screws to hold the stand rods in place.
I ended up having to make a tap extension to tap the holes.
only thing left to do on these parts is mounting holes for the flame guard.
Next need to round up material for the bottom ring.
