Nice job on the blades Shred!
Well got a little done here is what I got.
Grabbed a piece of material and cut up 2 blocks squared them up and laided them out
Notches on sides cut ready to go to lathe or mill and drill and bore the cylinder bore.
Decided to put them in a 4jaw chuck and do them on the lathe.
Ok bores are done except for lapping to be done last. Now to turn up a mandrel and turn the cooling fins.
Got mandrel turned and first part mounted and ready to start.
The spookiest slot cut the first one because it is up against the base of cylinder the rest will be a piece of cake.
One down one to go going smoothly for a change.
Drill mounting holes.
I knew it was to good to be true. Slight miscalculation on my part. I wanted to leave outside of cylinder square to have just a tad bit more cooling surface. But as you see the screws need to have more clearance.
No problem took a ball end mill and relieved the bottom 3 fins slightly and still have that little extra cooling surface.
Done except for the lapping.
Haven t decided what to work next. Still want to get some practice in on silver soldering some .031 brass to see how it goes.
