Mosey said:Since we are building fans, I thought you might enjoy seeing a real fan.
I almost did a 9 blade fan but the endmill was getting a bit small. What is that fan on? Duelly pickup?
Mosey said:I guess the gauntlet has been thrown. I will try to build a 9-blader next week when I get back to the shop. I have some tiny mills that I found in a box for circuit boards. 1/8", 1/16"?
This is fun.
I don't know how I can mill the angled blades in a manual mill if they are wider at the tip than the hub. I'm thinking that it might be best to cut the (9) blades out of a single thin sheet of alum, and then press each blade individually into an angle or a curved form, then bolt the 9-blade sheet onto the hub. Ideas?stevehuckss396 said:I used a 1/16 ball nose
Mosey said:I don't know how I can mill the angled blades in a manual mill if they are wider at the tip than the hub. I'm thinking that it might be best to cut the (9) blades out of a single thin sheet of alum, and then press each blade individually into an angle or a curved form, then bolt the 9-blade sheet onto the hub. Ideas?
Curiously assymetric, aren't they? I suspect that my engine will not have a problem because of running too fast. I want fan noise!Lakc said:Note that those 9 blades are assymetrical, yet balanced. I am sure there is more then one reason for that, but it cuts down on fan noise.
Mosey said:You see the problem that if the blades are wider at the tip than the hub, then it will be hairy to mill them unless they are flat, and then get twisted into the angle?
cfellows said:Heck, who needs an engine. That little assembly by itself it really slick. I could see that sitting on a bookshelf in my study, waiting for someone to come along and flick it over a few times! Pretty nice, Steve!
Chuck
