J. Tranter
- Jul 8, 2007
- 126
- 0
That looks and runs great. Thanks for posting this. I am still working on mine I can only hope it turns out as good as yours.
J. Tranter
J. Tranter
I used "what I had", which no doubt would horrify any Proper Model Engineers . IIRC that was a fine-thread 5/16" and maybe 3/8", but I think they're both 5/16" UNF (-24?). As long as you plan to make the mating parts yourself (safety/filler/steam/gauge/plugs/etc-- model boiler fittings are only made in a few thread styles), and have enough threads for strength it should be ok. At a guess the holes were 1/2"-- some convenient size on the step drill anyway. I used 3/4" bronze to make the bushings, but turned it down to 9/16" or so for the flange.J. Tranter said:Shred a couple of questions if you remember. What size holes did you drill for the bushings and what thread did you use for them? The plans call for an 8 and 10mm thread I believe and I'm wondering if I should go and buy metric taps or if I can use what I have.
Thank you for any help you can give.
J. Tranter
Al-bronze for the bushings I don't know about. I was all set to use some brass I had, remembering my old Mamod, but after reading about de-zincification, and not wanting to risk it I went out and got a foot (well, 13".. I have no idea why bronze is sold in 13" lengths) of regular bronze for the job. Enco puts it on sale a lot. You might want to ask the boiler specialists about Al-Bronze (if any are reading this, chime in!).J. Tranter said:Thanks for the reply. Will aluminum bronze be ok for the bushings? And what gas jet did you wind up using? Thank you for all your help.
J. Tranter
Thanks for the expert advice Sandy-- I confess to not being very happy about loctiting the jet in, though I did use #620 hi-temp Loctite and have limited the gas valve itself so even flat out it would only make a medium-size flamethrower Unfortunately (well, not that unfortunately, I have even less access to BA taps) it didn't seem to match a BA thread either-- it was somewhere between 3.5 and 4mm x 0.5mm thread, though I've forgotten the exact details. What I'll do is silver-solder the current jet into another threaded piece that has a thread I do know so I can still fish it out for cleaning, but not worry about it coming loose.SandyC said:Hi Shred,
It looks like you are having a great deal of fun with that loco and what a great job you are making of it.
You mentioned that your gas jet had a weird 'metric' sort of thread..... well, the majority of the small gas jets used by manufacturers of camping gas cookers, DIY blowlamps and model steam loco's ('G' gauge etc) have a 1BA thread..... which is based on a metric form..... 5.3mm OD x 0.899mm pitch (0.2087" dia x 0.0354" pitch (28.25 TPI))
Number 5 which has a 0.2mm dia jet bore
SandyC. ;D ;D
BTW Shred..... Might I suggest that you keep a very very close eye on the LOCTITE joint you used for the GAS jet on your burner...... Loctite is not very good at high temperatures, and if the jet comes loose it can easily be forced out by the gas (typically 25psi pressure @ room temperature, but much higher depending on temperature... can reach 6BAR (87psi @ 40deg C))....well.....you don't want to see the results..... much better to get the right tap and screw the jet in. :'( :'(.... PLAY SAFE.
it was less than an hour's work to turn up a threaded sleeve, silver solder the gas jet in, tap the burner and reassemble it all properly.
It's O-gauge track, but it's 'narrow gauge' for the scale, if the term 'scale' still applies In theory it can run on the next size up track (Gauge 1) by moving the wheels outboard of the frame rails, but mine doesn't actually fit G1 track since the frame rails are a little too thick (I have resisted making the axles even longer to make a slammed 'hoopty' locomotive for wider-gauge track :bigartrans said:thats cool as hell but the nicest one I ever saw was relax just kidding sorry again the the past post that really is cool why don't we see any steam vapors what scale track is that ho g o very nice.where are the palns for that or is it your design.
Hmm.. I don't remember. I can check later. It's not terribly critical-- there's about half an inch sticking into the flue, and the air hole is just behind the plug, so I suspect I put the center of the air hole 1" from the end. The rest of it holds the jet in place and you may want to shorten that or make it right-angle to clean up the plumbing. The flue end has the slotted tube telescoped into it, so as long as it grips that tube well and puts the first slot around 0.75" from the plug, it should be ok. The idea is that the slotted tube can be moved and rotated for tuning or replaced to try different slot configurations.J. Tranter said:Shred what size did you cut the 3/8 tube on your burner?
John Tranter
