Sorry Nerd, I didn't understand that comment. I understand the pair of rods to the top piston to be 180 degrees from the crankpin of the bottom rod n piston. - That's wjat makes this engine work. The valves, timing etc. are separate to Crank pins.
Or have I mixed the Doxford opposed piston engine design with something else?
I understand that modern Ship engines like this are Blown 2-strokes with a separate valve operation to open and blow in the central cylinder port from the supercharger/blower, with valve timed just after the exhaust port (near end of stroke of each piston) has opened, then the inlet valve stays open until after the exhaust port closes. But that is with inlet valve timing from a cam, not one of the cranks. So should not affect the Crank balance...
But the Fairbanks-Morse engine (picture attached) has inlet port at one end of the expanded combustion chamber and Exhaust ports at the other end. So maybe this is what you are referring to? - Except this doesn't need any offset from the 180degree crank arrangement either? - I am confused? - Or wrong?
The Fairbanks-Morse uses a pair of crankshafts, so maybe they are not timed at 180degrees separation? (looking closely at the pictures). - This is all new to me, so I am just a beginner - learning!
So the cylinder ports can be timed by the crank pin timing - a way from 180degrees - as you are suggesting? (IF I understand your ideas?). What did Fairbanks-Morse do?
Perhaps Ray can explain his engine when he returns from his other duties in a few days? Meanwhile we can chat among ourselves - if you wish?
Ken
