Brian Rupnow said:Unfortunately there are no British Imperial size shafting that corresponds to 4mm, so I bumped the 4mm shafting up to 3/16" which is 4.76mm.
Brian Rupnow said:How hot has it been Stew? We are into our early fall "normal" here which is about 20C daytime highs (about 70 degrees F), cooling off to about 40F at night. You are in England, aren't you?
One thing I noticed this morning while building the cam.--On previous cams I have built, the hub was offset to one side with the set screw in the offset part. This let me "play with" the valve timing until the engine worked at its best. This cam is going to be a beast to adjust as it requires dismantling the eccentric strap to get at the set screw.
