jixxerbill
- Jan 11, 2013
- 114
- 24
Great job Brian. Thanks so much for the pics and the explaining how you done things. I cant wait to see it run. Bill
but its leaking compression thru the exhaust valve. I'm about to quit for the day now, as I can only handle so much frustration at one setting
Luc---See posts 149 and 150.
Well actually Luc--I cut the seat at 45 degrees because thats the angle at which I made my manual valve seat cutter, and cut the valve at 46 degrees because I can manually adjust my lathe compound to whatever angle I want.Brian
are you cutting your seat at 44 degree and valve at 45 this will put your matting surface right in the middle
Hope it's help you
cheers
