Macc Models have 1/8" 3.175mm 6" and 5" tube that I was planning on using. Certainly a lot to think about.
Thank you for your effort mr steamchick.Not knowing exactly what you want to calculate, I found a couple of pages:
https://www.rasmech.com/blog/boiler-formulas-and-other-useful-calculations/https://www.zgindustrialboiler.com/... is the formula for,length x number of tubes.https://www5.eere.energy.gov/manufa...nt/amo_steam_tool/equipBoiler?random=satSteam
Hope there is something of use to you?
I would recommend staying as far away from biomass as possible. Its not the burning that is a problem, it is the ash softening temperature which is low. The ash melts and its a major design issue of getting it out of a unit if not impossible. Basically the bulk furnace temperature must be kept low. And the second problem is bio mass could be just about anything! But for this conversation we will define it as grass and other organic material. Wood is sometimes classified as bio mass but it can have the same issue.Useful for straight forward type substances.
Now what about for bio-mass - - - and that would likely also depend upon the type of (I would bet!)?
TIA
Hi Ajoeiam.
A Yarrow Boiler is also a very "fast" steamer, as a 3-drum water tube boiler. Used by many Naval vessels where maximum steaming was important, not fuel economy.
I don't know the Thorndyke design you reference...
Apparently, in a book there is a reference to the "Lune Valley" boiler, and Bolsover express boiler, both of which are supposed to be very fast steamers. - Reputed to generate up to 5cu,.in of evaporation per 100sq.in. of heating surface. This is a top limit, so whatever boiler configuration you use should consider this factor as a maximum for steam production (heat flow to water) and typically flue-tube boilers can only achieve 2 cu.in. boiling per 100sq.in of surface area, max. Many water tube boilers are a combination of the 2 designs, so considerations must ne given to the cooling of burner exhaust that proportionately reduces the heat flow into steam production.
Otherwise you are into the realms of coiled-tube and flash boilers for high-volume steam generation.
Babcocks water tube boilers have been a standard for Power Stations (coal and oil fired) and are generally water tube boilers.
For models, especially boats - with continuous return feed of condensate, a "Scott" boiler is proposed in some books. Silmply loops of tube mounted beneath the large Boiler tube. One end of each tube is low on the main tank, whereas the other end is higher, promoting fast circulation, and the water tubes are "in the fire".
Maybe this helps?
The size boiler you are considering is not considered a small boiler. Based on conversion from kw to btu and using 1000btu/lb steam its a small residential size boiler. ASME lists a minature boiler at less then 100 psi and no more than 16 inches in diameter. If you are looking at fuel efficiency then use 78% efficiency to back calculate the fuel consumption. Do not build a boiler for 100kw and run it at 25 kw. This is on the limit of a turndown ratio. You can build this thing but it will never be certified or legal in most places unless its done under an ASME stamp shop. The efficiency number is based on gas fuel and a well designed furnace.Thanks - - - I have read of the Yarrow and some others and have tried to chase things Naval as they were still using steam in some applications until even the 1950s (and past) see the Skinner Unaflow engines. From what I can determine these Unaflow engines (even looking at Dan Gelbart's very modern rendition) were actually quite efficient.
So then I come to what is an efficient boiler design - - - ie maximum steam at T (likely only 300 to maybe 600F) at a pressure of (again likely lower something like 300 to 500 psi (above atmospheric). And there everything grinds to a halt! No matter what combination of search terms I'm using I just can't find any comments regarding steam production efficiency.
Compounding the problem is that I'm looking in the 25 kW to maybe as much as 100 kW size for the boiler. That's been long considered 'tiny' by anyone working with steam.
So - - - any ideas for an efficient steam production design - - - or is this 'fast' have to do? (I am worried about fuel consumption!!!)
TIA
Steamchick, thank you for taking the time to teach this old Geordie a few things about boilers and requirements. I like how you are making sure that I build a SAFE boiler.Hi Raygers. The BEST option is to contact Ernest Winter = and get a copy of the calculations for
Ernest is the guy that is declaring the design to be good for 100psi Max working pressure, but before you buy material, you need to be sure it complies with appropriate legislation. That is, IF you want to be covered by Insurance if anything goes wrong. As you are in Canada, I don't know the laws, etc, that apply to you. But I am pretty sure the Canadians will apply ASME (The USA Regulations) or their own regulations that are basically the same. Your local Steam Model Engineering club will be able to advise, I reckon.
- the tube strength of the outer boiler shell tube - 6inch - in TENSION (HOOP stress) - with consideration for the stress raising factors (3.3 for ASME) to be applied for the shell tube penetrations.
- the tube strength of the inner boiler shell tube - 5inch - in COMPRESSION (HOOP stress) - with consideration for the stress raising factors (3.3 for ASME) to be applied for the shell tube penetrations.
All I know is how to do the stress calculations at inner and outer surfaces of thick-walled tubes, from University papers, and other Engineering texts, and by applying some second-hand knowledge from ASME Regulations for Pressure vessels and boilers. Some of this is from magazine articles by Kozo Hiraoka, and other internet sources about ASME regulations.
A few simple ASME rules I use: see attached Word doc.
e.g.
e.g.
- Copper at 100psi in tension must not exceed 3142psi tensile stress (by calculation) - including a stress concentration factor of 3.3 where ANY penetrations exist in the shell of the pressure vessel.
- In compression, there are complex tables to determine factors to develop the maximum permissible COMPRESSIVE strength that the Regulations will allow. Also, this must consider a stress concentration factor of 3.3 when penetrations exist - or perhaps something else? - when considering hoop stress.
- Rivetted boilers are NOT PERMITTED.
- Silver soldered COPPER boilers are not be permitted above 100psi NWP.
- A drawing dated 2018 must comply with whatever Canada have as their Regulations - including calculations. A boiler inspector will want to see these before he tests a boiler. Material certificates, components before and sub-assemblies during manufacture of the boiler may also be necessary. Talk to him FIRST. He may accept the design as drawn as complying with 2018 regulations? - Therefore OK?
- If you choose to change ANYTHING from the design selected, then it becomes a NEW design and must comply with LATEST Regulations. e.g. changing tube sizes to Tenor's optimised design?
Thickness of shells under internal pressure:
Min thickness shall be that calculated, for the pressure, plus any additional loading stresses as per UG22.
Circumferential stress: (When t < Rinside/2, or P =<0.385 S x E):
T = PR/(SE-0.6P) or P = SEt/(R + 0.6t)
where:
E = joint efficiency (for seamless tube & good design of silver soldered joints, E = 1)
P = Design Pressure,
R = Inside radius of tube or part considered,
t = min thickness of shell or component,
S = max allowable stress value.
I reckon this works out as:
R/2 = 1.25"< which is greater than t (wall thickness = 1/8"):
So: 1/8" wall of 6" tube:
P = SEt/(R + 0.6t) = 3142 x 1 x 0.125 / (2.375 + 0.6 x 0.125)
= 392.75 / (2.375 + 0.075) = 392.75 / 2.45 = 160psi.
BUT applying a stress concentration factor of 3.3 (Because the tube has "Penetrations" - covered in a different part of the Regulations!) this is reduced to 48 psi NWP!! = less than half of the proposed 100psi NWP.
That is why I think the design is not suitable for current Regulations.
But the Bottom line is that Ernest Winter produced the drawings, so he may have the calculations appropriate to his design, which you can discuss with your "boiler inspector". Well worth starting there, as when you have spent many hours and the Boiler inspector says "Sorry, that is no good. It does not comply with the Regulations." it is an expensive lesson to learn.
There are many experts on this forum - but I do not know if there are any Pressure Vessel experts who can advise better than this?
I am NOT a Pressure Vessel expert, but have been in industry and designed systems that had to comply to pressure regulations. (Out-of-date, UK. regs.). So if any Experts from Canada or USA can correct me I shall be glad to learn.
Thanks,
Martin: Just for your information the boiler shown would be outside of ASME miniature boiler classification as it exceeds 250pig. I would call this an A frame quite common in larger sizes. The ASME , API, and ANSI standards often overlap and the material code will let you know what standards they adhere to. Sometimes the prefix will tell you which codes they comply with.There's a lot happened since I last checked in.
Steamchick,
I am a bit surprised by the numbers for tube wall thickness coming out for Rayger's boiler. What makes me wonder is that the boiler for the 3" scale Atkinson wagon is 7" barrell but specifies 1/8" copper for 100 psi W.P. The stress concentration factor you are quoting for any shell opening just sounds rather high to me. It may well be right and ASME are uber conservative - that certainly happens having dealt with the UK approval body on steel boilers. I specced 16mm plate which was OK in the calculations, but they then bump it to 20 mm. I am not sure it is clever engineering as extra thickness will not "breathe" as the boiler cycles hot / cold. Remember, the strongest trees bend in the wind........ Most boiler problems I have seen are localised cracking in firebox corners and such like, where there is no room for deflection again.
HMEL
I agree that a good starting point for guessing required grate area to produce a given amount of steam is a boiler efficiency. I think your suggested figure of 78% would be good for full size work, but optimistic for small work. As you get smaller, it gets difficult to cram enough heat exchange surface into a give volume without running into problems like insufficient space between tubes. Remember that most of the boiler codes stipulate a minimum value on tube ligament or spacing. For the British Standard that I designed to it was 1/2" and that severely limits how many tubes you can get in. That being so, the efficiency drops away quite sharply. Strangely, it can come up again on copper boilers because you can use thinner material and smaller tube spacings. I think Steamchick is nearer the mark at 70%, and I would go down to 60% on steel boilers.
AJOEIAM,
I understand your frustration about not being able to start. Most real engineers start from something else and adapt. (Some call it copying). In that spirit, I attach an outline of a largish design of Yarrow boiler from the Steam Boat Association of Great Britain. You might do well to make contact with the USA steam boat guys, they will be using similar boilers under similar conditions, so will have a better handle on the right tool for the job. The full design of the 3 drum would be OK to UK standards, not necessarily to USA standards - Even though we all have to work to API tube sizes over here, because that is all you can get in certified material in UK.
I also sympathise over the complexity of calculations. The problem is you may well find such a such a tube will evaporate X per square foot or similar "rules". What they really mean is that in a certain case that tube evaporated X per sq foot - but you might well be working with a different fuel, different size, different configuration, forced draught or natural draught etc. etc. So such guides are useful for a first cut, but can be widely out in the overall scheme.
Martin
