ajoeiam
- Aug 14, 2020
- 1,042
- 308
Have you asked Macc models what they would recommend for your boiler? - They may suggest the tubes are "OK or NOT"? - Or not give a judgement... if you need something they cannot supply....?
snip
But we do not use BS 14276 for rating boiler designs.... Do you know what is used in Canada? - I found this: which may give exemption to your boiler? (for Saskatchewan?).
https://www.tsask.ca/uploads/File/PDFs/Legislation/boiler_pressure_vessel_act.pdfExcepted:
(f) a high pressure boiler that has a heating surface with an area of two square metres or less;
(h) a pressure vessel that has a volume of 0.0425 cubic metres or less; (i) a pressure vessel that has an internal diameter of 152 millimetres or less;
So that puts a different perspective on things. - You are allowed to make a bomb!
But please excuse me for not attending the operation of the boiler...
OK - - - so if I use a water wall (tubes with steel welded in between so a sealed surface do I use the overall area or is it necessary to calculate the exact amount of perimeter of the tube's fire side facing or is it something else?
(This is where more information almost doesn't help - - - its like I'm needing definitions of the the definitions of the definitions. It shouldn't be that way - - - for pete's sake we've been doing this for at least a 100 years. But then I guess obfuscation makes for more work for those with the 'stamp'. )
When I look at the Raygens (sorry likely mis-spelled) spreadsheet - - - -there are absolutely NO calculations.
I was hoping that I could determine how those numbers were arrived at. Rather the spreadsheet just presents the values as fait d'accompli !
