After what seemed to be far more struggle than I anticipated, the tailstock alignment is correct within .001" of being the same as the center in the headstock spindle. I ended up machining two ends of a bar held between centers and adjusting the tailstock until I was getting micrometer readings within .001" of each other at each end, and said "That's it!!!". I made a lathe dog to drive the bar that was held between centers, and was really surprised how much it threw the lathe out of balance. I would have liked to run the lathe at 800 rpm to get a really good finish on the two areas I turned, but at anything over 350 rpm the lathe wanted to levitate. I will have to add counterweights to the faceplate when I turn the crankshaft between centers using a lathe dog.
