Niels Abildgaard
- Jun 13, 2010
- 569
- 107
Your method will work just as well for a V2 crank.Hi Pat
In order to be able to produce and assemble the crankshaft in a straight line, I used an auxiliary mandrel.
(In German: "Hilfsdorn", google translater found only the words "auxiliary mandrel" for it.)
It is a steel bolt that has been precisely ground for a slight tight fit.
I didn't mark the connecting rods in the sketch, but they were of course installed.
For the assembly of the crankshaft, the bolt was used as a guide/alignment.
For the final machining (cylindrical grinding plain bearing seat) of the front and rear crankshaft diameters,
the crankshaft was clamped between centers on the cylindrical grinding machine.
Only when the grinding work was finished and the crankshaft was secured with pins,
the bolt was pulled out and the hole in the middle part closed.
Because the crankshaft was case-hardened,
I had to drill the holes in the assembled state with a solid carbide drill Ø 2 mm.
Then hammer in the pins and it was done.
Dieter
I used this type of locking pin (Ø 2 mm)
Edit:
I forgot to mention, the engine run about 11,000 revolutions per minute.
It depends on the propeller you use.
I have tried to compare mass for Your pressed version with my screwed and difference for a 5ccm V2 will be less than half a gram.
ByeBye feeling a genious on that account but it was nice,free and unpoluting as long as it lasted.
Thank You for describing it so well.
