There are no leaks in the crankcase. However, that being said, there are no shaft seals on this engine. I am completely out of tricks that I would normally use to start an engine.---tried them all yesterday. The engine fires, and fires very consistently when turned by the drill motor, but won't keep running on it's own. I have tried the ignition timing on every setting, and although it makes a difference, it doesn't make enough difference for the engine to catch and "take off". Likewise, I have tried every possible needle valve setting. This engine seems to fire more consistently on what I would deem a very rich mix if it was a four cycle engine. Today I will do the "easy" stuff---I will start by lowering the gas tank to see what effect that has. I will try and feel for carburetor suction, and may put a piece of clear plastic tube from the intake pipe to a glass of water to see if it is blowing bubbles when I turn the engine over by hand to see if the round ball in the carburetor is sealing the way it is supposed to. If that fails, i may try glow fuel and a glow plug, which are recommended for this engine by the original designer. (He claims that though the engine will run on gasoline, it starts much easier on a glow plug set-up.) What do people generally do for crankshaft seals on an engine like this, where the crankshaft is only 3/8" diameter?----Brian
