This is maybe a good spot to insert some miscellaneous items.
GASKET MAKING
My instinct was that gaskets on specific mating surfaces they would be beneficial. Or at least that’s what I usually see present on commercial engines to seal air/gas, fluids or even help with fastener retention under vibration or heat cycles. The plans were a bit vague on this other than the nose case oil bath area.
I did some experimenting with typical squeeze tube type sealant/gasket products with mixed success. There are so many products out there & admittedly I don’t really understand the variations of metal-to-metal vs in conjunction with gaskets. Actually, of the goopy products I liked, the problem was usually they worked too well. Disassembling the engine parts was quite difficult because of their delicate size & cleaning off stuck residue was a chore. I expect to be in & out of the engine often so I wanted something that lent itself to that. I can produce CAD based export formats for a computerized cutter, I don’t have a machine & it seemed excessive to outsource it for the low parts count plus spares. I see there are some interesting cutting machines used by crafters for cutting stickers & such, but I suspect the software/import capability might be another rabbit hole & again hard for me to justify.
So, I went old school & just hand-made ‘acceptable accuracy’ templates from scrap MDF to act as a cutting guide. I laminated my paper shop drawings onto the MDF & cut them out on the scroll saw. The gasket material I found (actually copied from another builder on the forum) was Teflon sheet, I believe also known as PTFE. The nice thing is it comes in very thin sheet thicknesses, starting at 0.001” depending on the supplier. Its impervious to oil & fuel & even used as head gaskets that see significant heat. I sprayed a light mist coat of adhesive onto the material which tacks it into position on the template. Then cut the outline along the template with a sharp Xacto or scalpel on a cutting mat.
I first tried drilling the gasket clearance holes for, in my case, M3 fasteners to pass through but a drill seems to make a raggedy non-circular profile even with backing board behind. So, I made a simple tool from O1 so that I could harden it & preserve the cutting edge. I used a 4mm ball end mill which made a natural edge to the ~3mm shank. It cut the sheet with a slight twisting motion or using cordless drill. I think the slight give of the cutting mat helps & also preserves the cutting edge. A punch style template might make better holes but would involve another mated template. I also think a thinner, harder cutting template like 1mm aluminum or plastic might allow better access for the blade on internal holes, but the MDF will last for what I need it for. To release the finished gasket from the template, it just needs a spritz of acetone or thinner. The spray adhesive dissolves clean & the PTFE is impervious.
