Well, a bit of construction. I designed our house in Phils, and supervised the construction. I learned a whole lot. It's hurricane proof, earthquake proof, flood resistant, and bullet resistant and bomb resistant. The last two items NOT a priority but the first three extremely important. It is also built with a basement which is generally about 10-15degrees cooler than upstairs.Sounds like you where in Construction at one time .
I had difficulty finding the sun when I used the sextant - once - when in the Navy.
Decca navigator was dead easy though! Radar over the horizon was difficult to interpret if it didn't see houses or cliffs on the coastline, but only hills and mountains beyond? Dead reckoning was OK for the ship through water, and tidal flow, but wind drift was bit of a sod to estimate! And recognising your position on a strange new coastline was difficult, so we sailed to aim 25 Km North of the port (inlet or river mouth) so we knew which way to turn when we reached the coast. (South). - it was 35 miles South, so we would have hit the coast and been just out of sight (a bit foggy, 2 mile visibility) and not known which way to turn if we hadn't aimed further away than predicted error by a good chunk. Like reducing machine cuts when approaching size!
I Stuck to engine room stuff. Easier to understand big blown 2-stroke diesels!
Wish I had some of those, even tho' I have no use for them.
⫷⸻❋ project ❋⸻⫸ .
It would hard for any to build a GPS now looking at Sextant looks easy to me when break down.
Theis group of Sextant is size for most shops
What do you think ?
Here a few pocket Sextant from 3" to 4" dia.
Note the peep sight used
The VENEER is in minutes
Note some photos are dup. [/B] [/size]
Note the handle has a flat so does not turn in hands.
This is mostly in closed and the veneer..
Not finished
I have never use too.Wish I had some of those, even tho' I have no use for them.
I was surprised over just table .Wish I had some of those, even tho' I have no use for them.
Never used any but it would be fun to learn howI was surprised over just table .
Now if could only hold the sextant to a second. Lucky hole to 30 minutes . The next is try hole to a minute. Next is a very good watch.
I have a theodolite to 20 seconds is closest I have come to a sextant.
On ship I have been on ship is a ferry ⛴ in Washington state to Canada .
Did get see engines room.
Aircraft I can use a radio compass I spent a lot time flying ✈.
How about you ever use a theodolite/transit maybe a radio compass?
Come over I have a theodolite and have used it lot .Never used any but it would be fun to learn how
Can't do that right now. With modern equipment it should be easy to build oneCome over I have a theodolite and have used it lot .
It lot fun
I purchased a theodolite because the veneer is 20 seconds. I could turn corners of a build , upper door tracks and setting columns.
How build Hight, telephone pole Hight and locating the North start
The list just goes on.
I am here Clovis California
