1) Wow did I get an extreme example of a sun burn from 3 full days of motorcycle riding. Today's rain gave me the opportunity to take a break from the sun, finish up this build, and post the final results and pictures.
I used a brass 3/16" push rod attached to the cam follower with a 4-40 stud. On its front end a 4-40 cap screw and nut allow for adjustments. It is also a perfect fit for the end of the valve stem. The 3/4" long .020" exhaust valve spring was too stiff and required 20 psi to run the motor. I switched it to a ½ long .020" spring and it ran on 5 psi. Still not satisfied I tried a 3/4" long .016 spring and it ran on 2 psi! A motor that runs on low pressure is my goal and to me indicates a successful build. After a 15 minute break-in period it now runs well on 1psi every time.
2) The photo below shows the 6 bolt pattern I used on the valve and cylinder head. I like the look of cap screws on small areas like bearing blocks and cylinder heads. I also like button head screws on larger areas like supporting structures and bases. Purists will disagree with my choice but after all it is my build. I made the intake as a separate piece using 3/16" model pipe tapped 10-40.
3) The size of the exhaust pipe and its flange were kept to minimum since it is held on by two small 0-80 cap screws. The front of the bearing block that holds the cam gear was rounded to suit.
4) I used 660 bearing bronze for the crank bearings and cam roller. I was concerned that with out ball bearings, the use of plain bearings would cause too much friction. This could have prevented the crank from cycling 4 strokes for a return to the firing position.
I was wrong! The engine will easily cycle 6 to 8 strokes after cutting off a 1 to 2 psi supply pressure.
5) The birds-eye shot below shows the spacers I added between the fly wheels and bearing blocks to bulk up the look of the crank shaft. It seemed that the large 3" flywheels made the crank shaft look somewhat undersized.
6) This last photo shows a different angle of the gears and cam arrangement.
My thanks go out to both Chuck (cfellows) for providing the drawings and the additional build information I needed, and also to Gail (GailInNM) for generously donating the correct gears to make my build possible. I would also like to thank the rest of the members on this forum for their support and encouragement.
:bow: :bow:
-MB
