Thanks for the comments Carl,
I have not had much shop time for the last couple of days, but I think I am back on track now. If you look at the last photo in my last post, the piston on the right has a few marks just to the left of the flat on the crown of the piston. I had not clamped the piston tight enough when milling the flat and it rotated. The scars polished out enough that the piston would work OK, and once assembled nobody but me would know they were there. But, I would know they were there, so I mane a new piston to replace it. I also spent a few hours on machine preventative maintainance. I am now set up to start the contra pistons.
Since there is nothing done worthy of a photo, I wanted to answer Zee's questions.
The cylinders had no coating on them when they were put in the oven. They had been cleaned very well and all oils removed. The color is just the natural color of oxidation of the steel. If you Google "steel color temperature" you will find many color charts showing the colors at various temperatures. It gets the darkest at about 550 degrees F. The temperature is fairly critical as the color changes rapidly as you go through the 450 to 600 degree range. If you try it, try some scrap first as domestic ovens are not always calibrated very well. The oxide coating will provide very little, if any, corrosion protection, so the parts need to be oiled afterwards. The same is true of cold chemical blackening treatments. Parkerizing will provide good corrosion resistance, but will not be as black and uses heated solutions which I am not fond of.
For photos, I do not use any special lighting. Photos on the lathe are lighted by a 50 watt halogen work lamp. On the mill I have a 50 watt halogen lamp and a 23 watt fluorescent screw in bulb in articulated lamps. I position the lamps to minimize unwanted reflections. I use a macro setting on the camera, but to get a greater depth of field, I back up until the image only fills about 1/3 of the frame. I use a 10MP camera so there is lots of resolution to throw away. I generally put a white index card in an area outside the area that I will be cropping the image to. I do not set the light color temperature on the camera. It's a pain to do with the camera that I am using. Then I process the photo on the computer.
I use a simple photo editor called "click 2 crop" It's greatest virtue is that it is quick. I have more capable editors, but they take far more time to use. It is available at:
http://www.mazaika.com/click2crop.html
Costs about US$20, but you can download it and try it free for a week or two.
I mentioned a white card earlier. Before cropping, put the cursor on the white card and right click the mouse and it will adjust for the color temperature of your lighting. There is an auto adjust box that cleans up a lot of contrast problems also. Then I set the output format that I want. For this thread I am using 320 x 240 pixel output. Drag the crop lines around to get what you want on the original, and the follow on the output image shown on the split screen. For most of the images I use a sharpen tool and there are 4 levels of sharpening. If there are dark shadows in an area of interest I tweak the gamma a little bit. It really works on this program, at least I like the look for illustration purposes. I really like the program as you can tell. It has more features that I don't use, but the main thing is that it is fast. On average, I don't spend more than 15 seconds on a photo.
Tomorrow will be contra piston day, and maybe wrist pins.
Gail in NM
