- Feb 17, 2008
- 2,330
- 445
I received a PM today from an HMEM member who is starting to build a glow plug version of the Lobo Pup Twin. He asked for recommendation on the glow head and cylinder modifications.
I have sketched a glow head and revised cylinder of what should work OK. I have not tried this, but I have built successful side port induction glow engines following this general layout before. Unless I have overlooked something this should work OK, but no rash promises. Fins were added to the head as glow engines normally run hotter than compression ignition and the additional fins will help make up for the loss of two cooling fins on the cylinder. Everything else should remain the same between the two versions. The drawing is attached as a PDF file.
I forgot to dimension the counter bore for the head bolts on the drawing. It is 0.156.
Gail in NM
View attachment GLOWHEAD.pdf
Gail in NM
