Before making the rest of the parts that fill up the crankcase bottom, I made the four jigs and fixtures that are required to machine the parts and assemble them. Two are the split offset collets that are used to machine the crankpins on the center crankshafts. They are shown on sheet 3 of the drawings and are identical except for the bore size.
On sheet 4 is a simple U channel used to align the crankpins at 180 degrees and the only critical dimension on it is 0.281 depth, so no machining photos are included.
Last,also on sheet 4, is a tool to position the center crankshaft assembly in the crankcase so the 4-40 screw that locks it in place can be inserted. While it is not necessary, it will probably save time and frustration during assembly. Particularly on the third or fourth time I disassemble and reassemble it. No machining instructions are given for it. The 0.188 slot in the side is to allow the connecting rod to pass through and can be about anything you want as long as it is at least 0.188 wide and full depth.
I am detailing the split collets as many machinists have not made or used them. You can get by with out making them and setting everything up in a four jaw chuck, but I like the collets so I make them.
Two blanks are turned up from 1 inch diameter stock on the lathe. The lip is just to keep the split collet from sliding into the lathe collet or chuck. Then it is over to the mill where the blank is held in a vee block in the vice and indicated to locate the center.
The holes are center drilled and drilled in each collet. The 0.188 hole is just for stress relief and could be omitted as the collet will only be used for one or a few parts. The other hole on one was drilled and reamed to 0.250 to hold the rear half of the center crankshaft (3-3). On the other collet, the hole should have been drilled and reamed to 8mm, but i did not have a 8mm reamer, or even an 8mm drill. So I drilled under size with a 5/16 (0.313) drill and then opened the hole up with a letter "O" drill which is about 0.001 oversize. I think that it will work fine, but if I start getting a little bit of chatter when I start turning the crankpin I will just put a slip of thin paper in the hole with the crankshaft to increase the contact area.
With rods that fit the holes inserted in the holes I shimmed the small rod to make the holes horizontal. A 0.063 shim is needed for the 8mm collet and a 0.031 shim for the 0.250 collet. They are not critical, so any scrap about that thick will work.
A 0.063 thick by 2.5 inch diameter cutter was positioned over the top of the collet and lowered until a feeler gauge would just fit under it. Never lower the cutter onto the feeler gage as it is easy to damage a cutter. Either lower the cutter until the gauge will not slid under it, or position it low and raise it until the gauge fits.
The rods are removed and the cutter positioned to the side. The cutter is lowered to the center line of the collet. This distance will be the thickness of the feeler gauge plus half the diameter of the collet plus half the thickness of the cutter. In this case, 0.025 + 0.500 + 0.031, or 0.556 inch. Position the cutter so the center line is at the back edge of the part. This way the cutter will be conventional milling. Unless you enjoy buying new cutters it is not a good plan to climb mill with this type of setup. I fed to depth and then moved along the axis of the collet to complete the cut.
I mark my split collets with the offset and the bore size. I have a box of them and occasionally end up using them for other projects.
Deburr the collets.
Here are the finished collets and the other two fixtures I talked about in the beginning of this post.
With all this shown, I sometimes just band saw the slot in. Does not look as nice, but works as well.
Gail in NM
