Thanks to Zee, Vernon and Arnold. Like you, I read most posts on the forum, but respond to only a small percentage of them.
Re-reading the first part of my last post, it sounds like I was fishing for comments. Actually, I was trying to be humorous (poorly). But, comments are always helpful. It lets me know if I am including enough detail, or too much detail. Too little and the beginners get lost and too much bores the experts. And since this is both a design and build thread, I have tried to explain why I do things as well as just how I do things.
So without the humor, on to finishing up the top end of the Lobo.
The only thing left topside is to finish off the compression adjustment screws. Note to self: keep the screws associated with each cylinders during these operations.
I faced off the top of the head and turned the knurled part off the head. Then bored to remove the hex part inside so the drill would not be deflected when drilling the cross hole.
The screws were reinstalled in their cylinders and run down with fingers until they touched the contra-piston. I marked the screws with a felt marker with a line from the front to back of the engine. Each screw was installed in a collet block in the mill with the marks vertical and center drilled and drilled.
The handle was cut from music wire with a rotary tool (Dremel) and a cutoff wheel. It was cut a little long and then brought to size on the bench grinder and the ends rounded off and polished so they would not act like a cutting tool on bare finger tips when adjusting on a vibrating engine.
The handle was pressed into the crosshole on the adjusting screw and secured with a little bit of epoxy run down to fill the hole in the head of the adjusting screw. The hole was overfilled so epoxy was above the head. After curing , the epoxy was faced off in the lathe so it was flush with the top of the screw.
With the compression limiters installed on their respective screw, the screws were reinstalled in the cylinders and run down to the compression limiters. The reason for all the effort to align the holes in the adjustment screws was so the handles would be in approximately the same place during the running of the engine. Notice that since the compression limiters are 0.010 longer than where the screws were marked the compression screws are about 1/3 of a turn up in the photo from where they were marked ( 0.01 x thread turns per inch = 0.01 x 32 = 1/3 close enough). It is anticipated that when the engine is adjusted while running that these screws will be about 1/2 further out from here. We will see.
Gail in NM
