Thanks Dean.
I like this method as it is as quick to machine as using an arbor and takes less material than an arbor. Also it takes a lot less time to set up than using an indexing head and making an arbor.
Another off forum email asked if the Lobo could be made as a glow plug version instead of compression ignition. Fuel for compression ignition is not as easily available as is glow fuel because it is not as popular, at least in the United States. I responded directly to him, but thought others might be interested.
A glow version should be no problem. All the port timing is suitable so no changes would need to be made in the bottom end of the cylinder. The top end of the cylinder would need to be reduced in height to get the glow plug down to the right height because the contra piston would disappear. A standard glow plug is too large in diameter to just recess in a new head. I did a couple of quick calculations, nothing final understand. I appears that to get the compression ratio in to the 6.5:1 area that the cylinder would have to be trimmed about 1/8 inch. This could be accomplished by removing one fin and one fin spacing from the top and by spacing the remaining fins a little closer by thinning the fins down. Glow engines run a little bit hotter than compression ignition engines, but the Lobo has lots of cooling. I can hold on to the cylinder for several seconds before becoming uncomfortable. The crankcase is rather massive and it get rid of a lot of heat also.
Should there be sufficient interest, after the current build is finished I can draw up the changes for a glow ignition engine. I will be ready to move on to something different by that time, so I probably would not build one myself.
Gail in NM
