Thanks, guys.
Spent most of the day in the shop today. I had to change the type of valve in the head. Didn't have much room, so the valve assembly had to be pretty small. Didn't take any pictures of the new arrangement. However, I do have the engine running quite well now. Here is the video!
[ame]http://www.youtube.com/watch?v=pGKmDTTE1To[/ame]
I had to fiddle around quite a bit with different springs on the slave valve. I actually learned something new about it today. In the past I had just depended on the spring to stop the ball slave valve at a reasonable distance and return it when the inlet valve closed. However, on this engine, the channel with the slave valve is quite long and so, necessarily was the spring. Unfortunately, this caused the engine to run eratically. So, I installed a pin which stops the ball slave valve, threading it so I could adjust the travel. Works great and greatly enhances the way the engine runs.
Chuck
