For the connecting rod I used a piece of steel 1/4 by 5/8 by 3 inches. I turned 2 1/2 down to 190 thousands that left a little extra for trimming at the final fitting. I threaded a small section of the .190 end 10-32 thread. This will screw into the crank shaft rod end. I faced the rectangle end to a 1/8 thickness which is being shown in this picture.
Starting to machine the crank shaft coupler. Closest to the size I had on hand was a piece of round brass so I am machining the rectangle shape in the Index VM.
Starting to take shape.
.311 was the size called for. I tried to get every dimension as close to perfect as possible. I want all parts to fit.
