Check out Bogstandard's drilled pliers tip. Most excellent devices for holding/bending round stock.zeeprogrammer said:I was thinking about bending it while it was hot...using some pliers or needle nose...any suggestions how I might do that without putting marks on the part? I'm going to look for some pliers that don't have the ridges on the end.
zeeprogrammer said:Did you heat, cool, and then bend?
Or, did you heat and bend while hot?
zeeprogrammer said:I'll probably take a run at heating and bending in brass. (Not because of 'instructions'...but I think there's more to learn and I don't think I've taken it far enough to convince myself it can't be done.)
mklotz said:A knurled lock nut wouldn't look right. Knurling is mainly for finger-sized things. Some sort of lever arrangement would be prototypical.
You can see it in the picture below.
zeeprogrammer said:The results... :rant:
Well that's just lousy. I've snapped three now. Robert - a few more than that.
Heated heated heated. Never got cherry red. Maybe my propane torch isn't big enough.
Robert...I appreciate the experiments...but the likelihood that the part will break again...after much work...isn't worth it.
For all approaches...wait until engine is down [sic] so I can see how far the stud turns when tightened..then mark where bend, tapped hole, or hole is made so handle is down rather than up.
mklotz said:Just a little preemptory hint here. You can alter the angle at which the handle reposes by calculating how much to take off the shoulder that seats when the handle is locked down.
You can use washers too but that's just plain tacky. No self-respecting model engineer would do something like that.
ariz said:zee your posts are usually long...
ariz said:but sometimes I read them, and I wish to compliment with you for your perseverance
ariz said:but I'm going out the thread, these are only thoughts in a late night, I apologize
