zeeprogrammer said:Thanks Vernon.
Thanks Bill. Looks like 60 degrees. Wonder if it helps to warm it up a bit?
Thanks Arnold.
From your drawing pic looks like the bend is around 15 degrees. Its a taper on the two flats from 0.15 to 0.080. The 13 number is ?? so took it to mean bend the handle (half inch long?) 0.13 off center which is close to 14.7 degrees (15). Thinking 60 degrees will snap it at the bend point.
Good idea to make a test piece and see how the bend goes as wlindiii just mentioned.
And what is that mystery piece
Robert
