Ciao ho visto che usu una cnc per tagliare, mi sai dire dove l'hai presa, o link del sito .grazie funziona bene?Just before Christmas I decided to get a CNC router. After much research the Onefinity is what I decided to go with. Being in the UK and they are in Canada, I was a little concerned! But all worked out well and all 3 boxes arrived safe and sound. It is their machinist version which has a 406 square machining footprint. I've set it up without the customary spoil board opting to inset a "T" slot plate into a sturdy laminated machine base? Aluminum plate eventually!
I operated a Fadal CNC with Virtual Gibbs for many years and putting a tool into the table would have resulted in a self inflicted fate worse than death.
Fusion CAM is what I am getting up to speed with, Amazing features! and once I get my head around it I will be fine but it is straining the grey matter at the moment. Very happy with the results so far. I was really struggling to figure out how I could reproduce the two levels on the front cover and blend them to the drive flange, it was keeping me awake at night.. Onwards and upwards.
Thanks. I will be painting Honda red. The pull start assembly will be made from aluminum also painted.Beautiful, are you going to paint the brass? originality
or beautiful brass?? always a dilemma. A very interesting
and beautiful build thanks for posting.
Onefinity CNCCiao ho visto che usu una cnc per tagliare, mi sai dire dove l'hai presa, o link del sito .grazie funziona bene?
È un capolavoro bravissimo, bisogna sapere lavorare e ci vuole tanto tempo. Io non sono al tuo livello, e non ho mai tempo.The pull starter is close to complete. I was going to go with a one way bearing but then started looking at the Zenoah starter. This is an excellent heavy duty assembly.
I also like the way you get some initial slack before the pawls engage and that it disengages completely as soon as the engine starts. With some adapting I was able to get the guts of it within the required size ally housing to look scale for this engine. I machined up a brass engagement drive dog that retains the flywheel.
The rest was some CNC work on the outer vents and then some long winded rotary machining of the peripheral slots. Happy with the result though. Just need to make a Delrin liner for the rope to run on.
