Micrometer Stand
bmac2
The other day I was doing that juggling act with a micrometer and started thinking I could really use a micrometer stand. Looked around on the Infomercial Superhighway and started getting a pattern together in my head. My plan was to print the patterns and when the 3 feet of snow in the back yard is gone cast them but the more I thought about it the more I felt that I should just print it. It’s not like I have to clamp down hard on the micrometer, I just want it to set still while I take a measurement and this is what I came up with.
My selection of colours was strictly based on using up filament that was close to “the end of the roll” so 2 colours it was.
I printed the fixed jaw in 2 pieces with holes for alignment pins to avoid having to use supports. I hate supports. The pins are just 14 gauge wire and then epoxied the 2 pieces. From the look of the prints I think my printer is due for another tune up.
The printed parts work fine but are to light. I didn’t want to have to slice off a 1/2in of 3 or 4in metal for the base but digging around in my stash I found a chunk about the right size that had started out life as a failed flywheel. I’d given up on it years ago because it was just nasty to machine but for this all I needed was weight.
I’d drawn it for M8 bolts but didn’t have any with a full thread so used 5/16in, there very close in size.
I put a light spring on the bolt between the fixed and moving jaws. It’s not necessary but does keep the bolt from just coming out the front. With some peel and stick foam on the jaws my 1in and 2in micrometers are held securely and with the weighted base I don’t have to chase it around the bench.
Nice work! A perfect project when you're stuck inside.
Can you share your files? I'm sure a lot of folks would like to make this.
-add some embellishment to it, maybe some raised text on the base, "BMAC 2025". (?)
Very nice design, if the STL is available, I’d love to make one for myself!
As far as the “Z” banding, depending on which printer you’re using, it might be something as simple as tightening the X axis rails (bed slinger) or just lubing up the Z rails on a Core XY.
One way or another, isn’t 3d printing just about the best addition to a well tooled shop?
John W
John W
I think it mostly just needs a good cleaning and a bit of a tune up. When I built mine it was more out of curiosity and wanting to build one more than a need. At the time my thought was “so after you print a Star Wars chess set what do you do with it”. But I’ve got over 1000 hours on it and it’s rare for it to sit idle for a week. It’s great for casting patterns, project enclosures and of course when my wife asks “can you make me a (thing) to do/hold (that)”.
I’ll try to get the STL files posted tomorrow.
I think it mostly just needs a good cleaning and a bit of a tune up. When I built mine it was more out of curiosity and wanting to build one more than a need. At the time my thought was “so after you print a Star Wars chess set whet do you do with it”. But I’ve got over 1000 hours on it and it’s rare for it to sit idle for a week. It’s great for casting patterns, project enclosures and of course when my wife asks “can you make me a (thing) to do/hold (that)”.
Agreed! I have a wife that also finds my shop an important adjunct to her “ideas” (aka whims), but by acceding to those ideas, it gives me more leeway when it’s time to buy new tools/tooling without further discussion! 😉
I like the design, especially when compared to others shown on Thingiverse, etc. looking forward to your files.
John W
John W
John I find I use Thingiverse more for inspiration than for final use. it seams there is always one or two small details I’m not happy with especially around hardware choices.
Do you care to share your files for this?
Ok for those who asked attached is a zip file with the .stl files. The printed base “large Round Base.stl” is to light to be of much use but it’s in there.
I’ve included my cad file in a step format that I think most programs can import.
  • Micrometer Stand.zip
    2.9 MB
I’m with you. Other than some of the items I feel are ready to go, I usually move the file to a CAD program and edit/customize it to fit my needs.
John W
