I used a domed lid, so that if the refractory cracked, it would not fall into the furnace (self-supporting Roman-arch thing), and I had inner and outer domed forms to create the 1" shape with Mizzou.
I used a chimney on top of the lid to try and retain the heat in the furnace just a bit longer.
The formwork for this lid did work and it turned out nicely, but it was all far more complex than it needed to be ( used an upper and lower domed form).
If I had to do over, I would have made the outer shell, found a dome of some type (generally the end of some air compressor tank or any domed shape of any material), and just packed 1" of plastic refractory on it, which would only take about 15 minutes, instead of the days it took me to make this lid.
It is best to work smarter, not harder, when building foundry equipment, and I often find myself using the "harder" methods, when I look back in retrospect.
